Results 1 to 10 of 15
Thread: New Pool Owner. Help!
    Jun 2011
    Southern Minnesota
    Default Re: New Pool Owner. Help!
    Thanks for the reply. I would rather keep they CYA high. The reason I put down 110 for the CYA was it looked like it would be 110. So it went past 100 and I guessed. Like I said in my first post, there is a long story behind this and know Im starting to understand things better. The pool co kept telling me to add more chlorine so I kept putting in the tabs. ALOT. Then she said oh, I meant liquid chlorine. I had never heard of that. So I would like to stay away from draining it. He is what they have done so far: I know this because they just left the empty bottles all over the pool area every time they left so I stuck them in recycle dumpster. Here goes:
    SoWhite Pool Clear: Sodium Hypo-12.5%.. 16 Jugs @ 128fl oz per jug
    AquaChem Sod Hypo 10%.. 6 jugs @ 1Gal per Jug
    Clorox: 10 Jugs @ 1.42Gal per jug
    OnGuard pH Rise..9lbs
    Natural Chemistry Metal Free 33.9fl oz
    " " Pool Magic + Phos Free 53.9fl oz
    OnGuard Chl Stabelizer 4Lbs
    Pro Team 3" High Tech Tabs 25Lbs(this was the tabs we were using when she said use chlorine. Used the whold bucket in a week or two)
    " " Multi Magic Shock 1 1/2 Lbs weekly
    That should be it. I stoped everything so I have not put anything in it or let the pool co do anything. Right know the pool is blue milky color and there are stains on the liner. I will wait on your advice. Thanks all. I hope I can have my pool party on Sunday....Lewis
    Steel Sided Pool/Vinyl Liner -- 26k gal
    PentAir Clean N Clear Plus Filter -- PentAir UltraFlow Pump
    Hi Lewis, welcome and thanks for the lifetime mem.
    It might not be a bad idea to drain off half your pool and refill...because they put a lot of useless junk in that may WELL make it more difficult to clear your pool...I don't know.
    Or you can go simple and hammer it with bleach. You CAN use Cal-Hypo but you have to watch the CH level and stop when it hits 400. Only use Cal-hypo that's 60% or higher chlorine, if you use it (none of the 48% wal-mart garbage).
    But Bleach or Liquid chlorine(LC) is the best way to go. 6% Liquid Chlorine is EXACTLY the same as 6% Ultra Bleach. Exactly.
    So? How much?
    Well, with your CYA over 100ppm, you need to shock your pool to get your FC up to 25ppm. That's going to take 10 gallons of 6% bleach, and you'll have to keep using it as one gallon will add 2.5ppm of chlorine.
    If you use 12.5% LC you'll need 4.8 gallons...might as well empty the entire 5 gallon carboy.
    I like the 12.5% in carboys because I use less gallon jugs, less hauling, and the normalized per gallon cost is cheaper (If a gallon of 12.5% is no more than double the price of a gallon of 6%, the chlorine in it is cheaper).
    But it doesn't matter. For convenience and cost I prefer the stronger stuff. Other people around the country find it more expensive or harder to come by and use bleach. As long as you use the correct amount it's no different.
    Jun 2011
    Southern Minnesota
    Thanks. So at 10:00 a.m. i put in 10 gal of bleach. It is know 4:00 p.m. when do i re test?
    When trying to clear up a pool, the more often you test and raise back up to shock level, the quicker it will clear, so go ahead and test when you can...
    Jun 2011
    Southern Minnesota
    Here is my latest test
    6:15 p.m. Sunny
    Pool Temp 85
    pH 7.2
    ALK 120ppm
    CAL 210ppm(question, its not a blue but more purple. Do I keep going til its blue?)
    FC 0.6ppm
    CC 0.8ppm
    Thanks all for your support and advice...Lewis
    You need to get the chlorine back up to 25 ppm...if it keeps yo-yoing up and down, the pool is not going to clear. Regarding the calcium, you keep adding drops until the last drop you added does not make a color change.
    Jun 2011
    Southern Minnesota
    A little confused. Would that be FC or CC or do i ad the two to get a total number? Also is it swimable or should i keep people out til it gets better? Thanks...
  1. New Pool Owner
    By HMSpool in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-20-2012, 10:32 PM
  2. New pool owner
    By Ameztoy in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 02-27-2012, 09:06 PM
  3. New Pool Owner!
    By Kainoa in forum Pool Equipment & Operations
    Last Post: 11-13-2011, 09:35 PM
  4. new home owner -- new pool owner -- clear as MUD
    By Andyman33 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 09-06-2011, 07:51 PM
  5. New Pool Owner
    By bobcat in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-25-2010, 03:03 PM
