Re: Rust on above ground steel pool
I think the size and location of the hole/s and how many would determine a safe repair. The pressure is greatest at the bottom.
I searched high and low to find out about this type of repair and came accross someone saying to get a roll of alum flashing and wrap the entire wall at the base. Personally I wouldnt try this unless the holes were smaller than a quarter, larger than that maybe galv sheet metal. I recently put a piece of alum flashing for a bunch of bb sized holes, but the were not more than 12" below the water line. Sanded them, primed and painted both inside and outside of the wall, duct taped the alum in place and good for several more years (I hope).
