8 days ought to be long enough. The CYA reagent clouds the water. The deeper you can see a dot at the bottom of the tube, the less CYA you have. The tube is graduated to read CYA level.Originally Posted by kjsmom
So --- Michael's calculator calls for 16 lb of cya to go from 10 (we had new water last Fall and only added some closing chems) to 85. I added 9 lbs in mid April. Then I added 4lb 6oz in the a.m. on 4/22 -- buy my husband backwashed in the p.m. so I assume that was washed out. Then I added the 5lb 10 oz on 5/1. Disregarding the 4lb 6 oz that was probably washed out, the remaining 14lb 10 oz should get me to 80 ppm, right???? I will take another sample there tomorrow and see if maybe they made a mistake. I think I will just trust that I know what has been added and see how well my cl holds. Thanks very much.
PAT
Did you backwash your pool in the meantime? If you added the CYA and then backwashed in a day or two, you would have flushed all the CYA you put in back out.
Why do you want to raise your CYA from 30ppm? That's generally an ideal number. Now you have 35ppm, so why raise it more?
You could slowly raise it by using a floater with Tri-Chlor pucks--just watch your pH because it will drop.
Still our first recommended range for CYA is 30-50ppm. You are right there!
On to testing: I test my CYA levels myself. I do it the same way everytime, so deviations are from my own tests and changes are baselined from my own tests.
Establishing baselines and normal ranges for the test site is very common. Every lab that runs blood chemistry and hematology tests sends along its baseline and normal ranges. These can then be "normalized" in pharmaceutical clinical trials so they can be compared meaningfully to other labs' tests when the new drug is submitted to the FDA for approval.
Pat,That is a very wise decision. Pool stores notoriously don't test accurately. Get a kit that tests for CYA (Ben's is the best) and your pool chemistry management will become amazingly accurate.I think I will just trust that I know what has been added and see how well my cl holds.
John, I've seen some of your other posts, and I am inclined to trust most everything you say. Until today I would have agreed with your assesment of the solubility of cya - however, I went back to a pool I had added 5 lbs of cya to 8 days ago and I saw ~ almost all of it still sitting on the bottom. Maybe it's the cold water or lack of a MD in an 8' deep pool (however there are low suction ports at the bottom of the wall and a couple of 'low returns' which should be 'stirring up' the water down there). Not to say you are wrong but, empirically it looks like some pools won't take the cya as quickly as others. No biggie, some pools apparently need more time to absorb the cyaOriginally Posted by JohnT
Just wanted other folks who still have the granuals in their pools to know that - they aren't the only ones![]()
Wow. I'm surprised, but not shocked. There are differences in the way pool water works that I don't know if anybody fully understands. As a counterpoint, if I put CYA in a sock in the skimmer of my pool, it will be gone completely overnight from the sock (no holesOriginally Posted by waste
). I was amazed the first time I saw it happen. Testing indicated very close to the expected CYA change less than 24 hours after putting it in there.
Hi, Ted/John
We're sort of hijacking this thread but, yeah, I'm in the dark as to the wide variance as well. My last CYA addition of 11 lbs (35ppm) tested complete after 48 hours.......possibly sooner. I wonder if the age of the product has any effect.
Ted, what are you doing putting that stuff in the pool where the customers can see it? HIDE it in the filter!!! If they backwash, you get to sell them more!!![]()
Dave, I'm shocked!Originally Posted by duraleigh
, you should know me well enough by now to know that I don't sell anything - (I know you were just kidding but I can't stand the fact that the company I work for uses the automated chem selling tester which usually ends up causing more problems than it solves and I can't get them to stop or tone it down because they make money off of it
(typical Waste post - I try to use some of the cooler functions available here and end up with the text saying what I wanted, but improperly formatted!! - sorry all!![]()
