Results 1 to 10 of 15
Thread: Shallow End for above ground pool
    Jun 2011
    Massachusetts
    Default Shallow End for above ground pool
    Hi,
    I have recently completed building a shallow end and steps for an above ground pool (18' x 52' intex)
    It covers about a 1/3 of the pool and allows the 4 year old to stand belly deep in a 4 foot pool but also allows the "adults" a good sized area to swim.
    Made from PVC unions/tubing/planking and cost under $300.
    I am hoping to post pictures once I receive the "good" forum access
    Jun 2011
    Massachusetts
    Default Re: Shallow End for above ground pool
    Thanks,
    The shallow end thing was the reason I found this forum in the first place.
    Looking forward to sharing.
    Send your pictures to poolforum AT gmail DOT com, and I'll post them.
    PoolDoc
    I, too, am curious, especially as to what you used for planking. PVC Planking? I hope you aren't using pressure-treated wood.
    I also hope you put extra vinyl under your platform supports to prevent abrasion. If not, Home Depot sells Plumber's Vinyl that's used to shower stalls. It's at least 40 mils thick and is super-smooth. I use it under my drop-in steps. Or use can pieces of liner.
    Jun 2011
    Massachusetts
    The Decking
    The planking is a product from Home Depot advertised on the shelf as "Garage Door Trim".
    It comes in 8 or 10 foot lengths and is 5 1/2 inches wide by 3/4 thick.
    It is very light (the 10 footer comes in around 2-3 pounds)
    It has 1/4 inch deep ridges on the underside. The top surface has a wood grain effect which in my opinion provides a decent non slip surface.
    It looks as though it is designed to be painted over, since who would want a bright white wood finish.
    The cost is about $16 for the 10'. I used nine of the 10s and one 8 footer.
    Just over half of the total cost came from the planking.
    I secured them to the 1 1/4 PVC tube with 3" countersunk galvanized machine screws/lock nuts.
    About $26 for a box of 100 and I used 98.
    If I can find a good online source, I will replace with stainless next year.
    (no sign of corrosion yet after 6 weeks submerged)
    The Frame/Structure
    1 1/4 pvc sched 40 tubing. I used 10 10 footers.
    I bought all of the unions online since I needed 4 and 5 ways which HD did not sell.
    They are furniture grade PVC connectors which I was happy to use since they have smoothed/beveled edges. The sched 40 ones were a bit rough.
    They cannot be used for plumbing.
    I used a combination of approx 30 T / 3 / 4 and 5 ways at about $2 a piece incl shipping from US Plastics http://www.usplastic.com/catalog/def...arentcatid=690
    Regular PVC cement.
    The planking is not as sturdy as I originally looked for, so I had to reduce the span width between tube supports to 24 inches.
    I would recommend 16" inch since my family are somewhat light weights.
    Assembly
    The whole thing took about 5-6 hours to build (maybe less if you are more used to working with PVC plumbing tube/unions).
    Note from experience: work from one corner to the opposite.
    Think about how the next 2 to 4 unions will go together and will the frame bend in that location to accommodate 2 joints at once.
    I tried to connect 3 pipe ends to one union at the same time but it was not easy and I would recommend thinking ahead and trying to avoid.
    Clean up the unions as you do each one since once the glue is dry it is much harder to remove and causes imperfections at the joints.
    Very Important: Remember to drill about 1/2 inch holes at all corners if you want it to be sunk.
    Tools
    Chop Saw
    Drill/Screw driver/Countersink
    Wrench
    Installation
    The whole thing weighed about 120 lbs.
    Easy for 2 to carry to the pool but it took 4 people to lift over the edge.
    At first it made a nice floating island. The PVC tubes and unions and hence frame would sink with no problems. But the planking is very bouyant.
    Once I stood in the middle of it, it became apparent that at least 100 lbs was needed to sink it (once all of the bubbles came out of the frame)
    I went for rocks but will be rethinking this next year.
    BigDave's Avatar
    Wow, Nice Donuts!
    Is the space under the platform small enough to exclude the small ones?
  1. How to convert a diving pool to a shallow pool?
    By popoapple in forum In-Ground Pool Construction and Repair
    Last Post: 06-07-2013, 04:05 PM
  2. Update of Shallow End for above ground pool
    By frizzell in forum General Interest
    Last Post: 04-03-2012, 04:07 PM
  3. Too Shallow!!
    By HAYMAN in forum In-Ground Pool Construction and Repair
    Last Post: 04-26-2006, 01:53 PM
