Re: Another Newbie - Getting the Pool Water Balanced
Thanks for the feedback ..... this is what I know now:
I already have a K-2006 test kit and I took a second reading this morning. The results are:
pH - less than 7.0 (the color scale doesn't go lower)
FC - 0.5 ppm
CC - 1.0 ppm
ALK - 100 ppm
CYA - greater than 110 ppm (again the scale doesn't go higher)
So, what I have done this morning is to drain approximately half of the pool (12,500 gallons) and I am presently in the process of refilling to the proper level with well water (this should be completed by 6:00 pm). I then plan to sufficiently blend the two water types overnight and then take another test.
I plan on going to the local grocery store to purchase chlorine and borax if need be. Do you have any suggestions on how much my initial purchase of bleach and borax should be?
Of course, any other suggestions that you might have would be most appreciated.
jhk49
