Pressure rising quickly
Great forum learned alot from reading but I am now stumped, Please HELP. I have a tagelus TA-50 sand filter with a 1.5 hp pump on a 20ft ag. I changed the sand in the filter before opening pool this year and yes used correct sand. When the system is on filter the pressure starts at 13psi with good flow back to pool. After about 30 mins. pressure rises to around 20psi and the flow almost stops. I have been running pool on recirculate but i need to filter so i can try and clear up this cloudy water. THANKS for any suggestions
