Thread: Algae ??
    Default Re: Algae ??
    Shock your pool up to about 15 and try and hold it there for a few days. Test 3x a day if you can and each time, add enough bleach to take it back up to shock level. You may just have something that you haven't killed yet and that is why it keeps coming back. If you'll look at the chart at the following link, you'll see that a FC of 6 is on the low side of the range that you should be keeping it at with a cya of 60. Hope this helps.
    http://www.poolforum.com/pf2/showthread.php?t=365
    Michigan
    Great !!
    So do you think it is Algae with the pool so clear ?
    duraleigh Guest
    Quote Originally Posted by aswetich
    Great !!
    No. But that's just guessing. Green algae is typically suspended.
    I like watermom's idea of shocking.....it's a cheap fix, and the results will be obvious. If it's still there after the shock, figure a way to get some out of the water and feel it brtween your fingers. If it's gritty, It's not algae. If it's slimy...it is almost surely organic but it sure doesn't look like algae.
