Thread: adding stabilizer with Kreepy Krawley connected to skimmer
    Jul 2011
    Default adding stabilizer with Kreepy Krawley connected to skimmer
    The directions say to add it slwoly into the skimmer. How do I do that? I ahve a kreepy krawley thing. DO I unhook the howe and remove the center section and pour the stabilizer in? I got one of those filter basket cloth filters. Do I remove it first? When I asked at the pool supply place about simply running the filter without the center secttio that holds the hose, the manager said to not do that--apparently I have to purchase a different center piece that reduces the amount of water flowing into the filter basket. So How do I add the stabilizer, and just how slow is slow? Thanks.
    CAN I safely run the pump without the center section all the time (no kreepy krawler hose attached and in place) or do I really need the reducer for it? Thanks.
    Ella5
    Default Re: adding stabilizer
    For now, pour the CYA (stabilizer) into and old sock, knot it, and hang it in front of a return.
    Regarding the Kreepy Krawley, take pictures of the skimmer, hose, your pool, and your pump and filter. Mail them to poolforum AT gmail DOT com. I don't understand what your dealer told you, but with pics I, or someone else, can probably figure it out.
