Results 1 to 10 of 13
Thread: Phosphates problem
    Jun 2011
    Default Re: Phosphates problem
    He said that phosphates are algae food, and as long as I have high phosphates, I'm going to be fighting it.
    Two days ago, I added 2 gallons of 10% sodium hypo, 2 pounds of super shock-n-swim (54% cal hypo), 12oz granular chlorine, and the recommended amount of algaecide. After all that, the FC was still 0.
    Yesterday, I added 6 gallons of 10% and 2x 1.84gal 6%. After the first 4 gallons, the FC was still 0.
    The pH was fine yesterday, but started to go down after I accidentally dumped out my floater while trying to pull it out of the pool. I just fished 3 pucks out, but I think there's still 3 in there. It's very difficult to retrieve things that you can't see. I added 1/2 box of borax right after I got back from the pool store, and the pH is now up to about 7. I just added the other 1/2, but most of it is still in the skimmer basket.
    The pool guy said to add 1 pound of super shock (68% cal hypo) now and 3 more tonight, since it will be used this evening. The 1 pound has cleared it up enough that I can now see the floor in the shallow end, and brought the FC up to >10 (the limit of my test strips). Using 1/2 pool water and 1/2 tap water shows the FC at about 6.
    Hi Reichhartkg;
    It sounds like you are trying to split the difference between our advice and the pool stores; if so, it won't work out well for ANYONE. You need to pick, for your own sake and your pool's sake: us or them!
    If you want us to help you, we need to know how many gallons are in your pool, and you need to stop all the pool store goop.
    Good luck!
    Jun 2011
    Quote Originally Posted by reichhartkg View Post
    Typical pool store mumbo jumbo. However, if you don't have any algae, there will be nothing to eat the phosphates, high level or not. The key is to prevent algae in the first place.
    The borax shouldn't be still sitting in the skimmer basket. You should pour it in slowly so it dissolves, not dump the whole box in one fell swoop.
    Seriously, and I know it's hard, I would disregard most of the advice of the pool store and follow directions here. For instance, that super shock you're using will raise you calcium level. High calcium can also lead to cloudy water (with high PH I think).
    All you need is bleach. And you need to keep the free chlorine at shock level based on your CYA until you pass the overnight free chlorine loss test. Something is consuming your chlorine and you need to keep shock level until it stops getting consumed.
    You are getting sound advice from us. We've seen LOTS of algae-filled pools and helped clear them up.
    Algaecide does no good. Most simply add high amounts of ammonia or copper to your water and make it harder to clear up. The ONLY one we recommend is Polyquat, but more as a preventative. If you add a quart of Polyquat to a 20,000 gallon pool, even with chlorine at shock levels, within 48 hours your chlorine level will be at or near zero. I'm not guessing on this--it's part of my closing routine in the fall. I run my chlorine up to 15 (shock level for my usual CYA leve). I add a full quart of Polyquat (I use about an ounce once a week if at all), wait 48 hours. My chlorine inevitable drops to zero. I then add bleach/liquid chlorine till I'm back at shock level and close.
    Other algaecides can cause foaming or gooping up as well.
    Add 3 kinds of chlorine, ie LC, Cal-Hypo and Di-Chlor (that granular chlorine you added) does NOTHING more than adding an equivalent amount of bleach. In the water, chlorine is chlorine.
    Your pool store guy wants to scare you into buying more stuff. And PhosFree is definitely "stuff". You've heard it here from several people: Phosphates can only feed algae if you HAVE algae. They can't magically produce it.
    Don't listen to the pool store advice. I can tell you with confidence you will get better advice here. How do I know? I've worked in pool stores!
    And we beat and harassed and annoyed it right out of him! :<
    Hey guys;
    Save your breath --- well, your keystrokes, anyhow. I just checked the activity log -- reichhartkg hasn't been back since my post about picking one or the other. Looks like he picked the pool store.
    Hope it works out for him!
    Jun 2011
    Nope... picked the rest of my life that also takes time.
  1. Phosphates
    By DJG36 in forum Dealing with Algae & Slime
    Last Post: 07-11-2012, 12:29 AM
  2. Phosphates
    By Wags3 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-20-2012, 08:27 PM
  3. Hi Phosphates
    By mkamp1515 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-31-2006, 10:41 AM
  4. phosphates
    By boscogabby in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-28-2006, 09:04 PM
