Re: BBB for small pool (6423 gallons)
I would not add anything else right now, as long as you're able to maintain a pH between 7.0 and 8.0, and maintain at least 3-4 ppm chlorine in the pool...at all times. Have you tested for chlorine again in the evening to make sure it's not dropping to zero? If you're maintaining chlorine and the pH doesnt' drop below 7.0 (dichlor is very acidic and will drive the pH downward), and the water is clear, then I wouldn't change anything else until the kit arrives and you can run a full set of tests.
Congratulations on doing your homework--it'll make caring for your pool SOOOO much easier!!
