Results 1 to 10 of 16
Thread: Pool Liner holes at Return Connection
    Jun 2011
    Default Pool Liner holes at Return Connection
    Hello, I'm new to having and taking care of pools. But here is a start to my problem.
    I have an above ground pool 18' round and 5' deep. I noticed that this year when I opened my pool I have a few holes in my liner right at the pool return eye. I bought a patch kit and I'm ready to patch it up but I dont know how to take apart the return connection.
    Can anyone help me or point me to a place I can find information?
    Jun 2011
    Default Re: Pool Liner holes at Return Connection
    OK Thanks PoolDoc, I sent them to you
    Welcome to the Forum!
    Once I see the pics, I'll tell you how I would go about patching the liner.
    Your pics are below. By the way, to remove the eyeball, just unscrew the nut in the first picture. You can hold on to the smaller hex flats next to the threads to keep the body from turning as you remove the nut.
    Ahhh, I see what happened! (thanks for the pics!)
    See the wrinkling above the return and the rips under it, and where it used to seal (the darker semicircle under the rips)? What happened is either that the r4eturn was originally cut in when the liner hadn't fully stretched into the floor/ cove, or the floor or cove washed out over the winter.
    Leave your water level where it is and remove the return (just like Ben told you, keep track of the gaskets and their orientation! and replace any that look worn. This will let the wrinkles settle down to partially cover the hole in the wall for the return. Carefully trim any liner that blocks the hole. Then apply a patch to fully cover the return hole and the rips + 1". Allow patch to fully seal, then cut an "X" across the wall hole and reinsert the return. Trim the liner that pokes through the back of the wall and retighten the retaining nut. Reattach the hose and you're ready to refill the pool and fire up the system
    p.s. - it looks like you have iron in the water.
    You can even replace the return entirely...that's a standard unit.
    Ted's given you great advice. It's much easier to patch a pool liner ABOVE the water than below it, and you get better results (I've done a number of underwater patches and hate doing it).
    I would take Ted's suggestion further: I like to patch about an inch around the holes, then put a bigger patch around the patch, again, at least an extra inch if not more. That helps prevent the edges of the important patch, the first one, from peeling. It seems like a lot of patching material but....it's a LOT cheaper than a new liner and may buy you a couple of years.
