Thread: Max Distance from Pool to Pump/Filter/Heater
    Jun 2011
    Dayton, OH
    Default Max Distance from Pool to Pump/Filter/Heater
    I'm putting in a new pool and I would like to locate the pump, filter, and heater in an existing building which is about 60 feet from one corner of the 20x40 pool.
    Would this be too far away?
    What is the maximum recommended distance for plumbing runs to and from the pool?
    Thanks for the help,
    Brent
    mas985's Avatar
    Pleasanton, CA
    Default Re: Max Distance from Pool to Pump/Filter/Heater
    There is really no limit to how far the equipment can be from the pool but there are consequences. The longer the runs, the more head loss there is in the plumbing and the less efficient the pump will be. You can compensate some by using larger pipes and/or multiple runs. For that length, I would use at least 2.5" pipe and have separate runs for each suction port (e.g. skimmer, main drain pair, cleaner, etc).
    Mark
  1. Need advice re: heater/pump/filter combo
    By ukdavo in forum Pool Equipment & Operations
    Last Post: 05-28-2013, 07:41 PM
  2. Pool needing complete overhaul! But i'm willing to go the distance.
    By OldPoolYoungKidFirstHouse in forum In-Ground Pool Construction and Repair
    Last Post: 07-06-2011, 02:59 PM
  3. Pump Distance
    By hoots in forum Pool Equipment & Operations
    Last Post: 05-08-2011, 06:28 PM
  4. Piping filter/pump/heater. Any tips?
    By cruzmisl in forum In-Ground Pool Construction and Repair
    Last Post: 05-25-2007, 11:52 AM
  5. Question about Solar Heating and Distance from Pool............
    By Player101 in forum Pool Equipment & Operations
    Last Post: 07-24-2006, 05:11 PM
