Results 1 to 9 of 9
Thread: Cloudy pool that wont hold Chlorine.
    Sep 2010
    Default Re: Cloudy pool that wont hold Chlorine.
    That is a BIG above ground pool!
    Yea, but is sure is nice. Up until this year it has been fairly easy to maintain also. We have a lot of "Get togethers" and its nice to have a large pool that the kids and the adults can get in and not be on top of each other. Our friends joke that we have an "Olympic Size Above Ground Pool"
    Sep 2010
    *UPDATE* ok I have been keeping the Chlorine @15ppm for the last 2 days and 3 nights, checking every night at dark then checking again when I wake up. Last night I only lost 1ppm. I would assume that what ever was eating up all the chlorine might be gone now and I can start letting the chlorine go back down to normal, correct? Here is my new readings:
    FC = 14
    CC = .5
    PH = 7.2
    TA = 70
    CH = 270
    During all this the CH did go up some. How would I lower it? I have been told I do not need any CH and that it may be the cause that my pool is still white cloudy.
    I have a fountain on the return right now trying to cool the pool off and I would assume that would also raise the PH. Once the PH is 7.4 I plan to raise the TA a little.
    Any thoughts?
    Brian
    33' AG 52" Side walls
    1.5 hp sand filter
    Had pool for 3 summers now !
    Hi Brian;
    Don't worry about the calcium - it may have been the problem, if you were adding cal hypo, but unless you are planning to STILL add it, it's not an issue now. Run your fountain, and keep your pH down, and the calcium will NOT be an issue.
    What sort of filter do you have?
  1. Pool is cloudy and PH / Chlorine wont come up!!
    By dxdodger in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-10-2013, 12:57 PM
  2. Pool wont register chlorine.
    By NJpool22 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-19-2012, 09:46 PM
  3. Need and experts help, my pool can't hold chlorine.
    By redlady in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-18-2011, 09:51 PM
  4. My pool won't hold chlorine
    By franzrinkleff in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-09-2006, 04:12 PM
