Hi Brian;
Don't worry about the calcium - it may have been the problem, if you were adding cal hypo, but unless you are planning to STILL add it, it's not an issue now. Run your fountain, and keep your pH down, and the calcium will NOT be an issue.
What sort of filter do you have?
