Re: Everything is good, but....
I'd found some of those threads but our case is different. We lost all our water over the winter when our old liner finally gave out, so this is fresh water as of 4 weeks ago. I added 4 lbs of CYA through the skimmer and ran two feeders of tri-chlor pucks to take the CYA up to 40 before I began on bleach. I'm testing in an hour and will again in the morning. What level should I look at keeping? Since the pool is in a garden we want to keep the chlorine low if possible. How low is too low, and what would be shock level for the rest of my readings?
