Re: Drop Based Borate Test Kit.
You posted about this kit in this thread at TFP where I speculated on how it might work. This kit doesn't compete with the K-2006 and the Amazon links to Amato that help The PoolForum don't include a borate test strip so I don't see a problem with you posting the link here. It does look like an interesting kit with clever reuse of some K-2006 reagents (R-0009 acid and R-0010 base; also R-0007 chlorine neutralizer) plus a couple of new reagents S-0009 and S-0010.
Since the kit is sold by a vendor in Canada, I wonder if importing it into the U.S. will have the high duty problems the Taylor kits have going the other way. Though the expense of the Taylor kits going to Canada is from the exclusive distributor Lowry & Associates, their high price is to cover the high costs for the paperwork/duties to import "hazardous" chemicals in the kit. The two added reagents in the kit are likely just Bromocresol green pH indicator dye and mannitol (a sugar substitute).
