Results 1 to 10 of 14
Thread: Need Help Please - just got my taylor 2006 testing kit...
Threaded View
  1. #3
    Default Re: Need Help Please - just got my taylor 2006 testing kit...
    NOT quite right, DurhamHouses.
    The first titration give you free chlorine, NOT total chlorine. After you add the R-0003 and titrate again you have the combined chlorine. The FAS-DPD test does not test total chlorine at all. If you want total chlorine just add the free chlorine and the combined chlorine.
    You are confusing FAS-DPD titration testing (used in the K-2006) with DPD (color matching) testing that is found in the K-2005 and other test kits. DPD tests Free Chlorine and Total Chlorine and you must subtact the Free Chlroine from the Total chlorine to get the combined chloirne. FAS-DPD directly tests for combined chlorine, DPD does not.
    If you have been subtracting the second reading from the first with an FAD-DPD test then you are not getting the correct number for FC if there is any combined chlorine present!.
  1. Taylor 2006 in Canada
    By PoolCanada in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-19-2012, 07:49 PM
  2. taylor- 2005 vs taylor-2006
    By axell in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 02-11-2012, 11:05 PM
  3. Taylor K-2005 vs. K-2006
    By myLABSpool in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-28-2010, 08:16 AM
  4. Fine Tuning Testing Precedure w/ Taylor 2006
    By Gracy101 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-08-2006, 09:36 PM
  5. Testing chlorine with Taylor K-2006 kit?
    By AndieP in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-07-2006, 06:15 PM
