Results 11 to 14 of 14
Thread: Need Help Please - just got my taylor 2006 testing kit...
    Default Re: Need Help Please - just got my taylor 2006 testing kit...
    Meanwhile, your chlorine for that level CYA should be adequate, but you need to test it, I'd say, at least twice a day until you have sufficient stabilizer to keep the UV from devouring your chlorine.
    BTW, your chemicals will last longer if you test 10ml of water rather than 25ml. Each drop of the test will then measure .5 rather than .2 and you'll use less. You don't need any greater accuracy than that.
    Jun 2011
    Northern VA
    Waterbear and CarlD, thank you so much for all the valuable information. It has made having a pool so much more FUN!
    27 ft x 52 in AGP
    Hayward Power flo LS 1.5 hp - Hayward model s180t sand filter
    27' round 17.2K gal AG pool; hand fed; Hayward model s180t sand filter sand filter; Hayward Power flo LS 1.5 hp pump; 24/7hrs; Taylor Complete FAS-DPD Pool Water Test Kit K-2006; orig. truck but use well to resupply; summer: ; winter: ; ; PF:7
    just wait...you will one day reach that point when you say "Do I REALLY need to test the water. It looks fine. Hand me a strip!"
    That is when you know the honeymoon with your pool is finally over!
    Jun 2011
    Northern VA
    LOL... hopefully that won't be too soon!!!
    27 ft x 52 in AGP
  1. Taylor 2006 in Canada
    By PoolCanada in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-19-2012, 07:49 PM
  2. taylor- 2005 vs taylor-2006
    By axell in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 02-11-2012, 11:05 PM
  3. Taylor K-2005 vs. K-2006
    By myLABSpool in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-28-2010, 08:16 AM
  4. Fine Tuning Testing Precedure w/ Taylor 2006
    By Gracy101 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-08-2006, 09:36 PM
  5. Testing chlorine with Taylor K-2006 kit?
    By AndieP in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-07-2006, 06:15 PM
