Are these results before or after you added the bleach and CYA? You need to keep some chlorine in the pool. Until you get a CYA reading which will be several days up to a week, you'll need to add bleach a couple of times per day. In this size pool, each quart of 6% bleach will add just under 2ppm of chlorine to the water. Morning and evening, add enough bleach to take your chlorine reading back up to about 6 or so. Once your CYA is dissolved, you'll be able to test and add bleach in the evenings only.
Your pH and alk look just fine.
Post your CYA reading about a week from now, you'll use the Best Guess chart in my signature below to help you determine what chlorine level you'll need. It is based on the CYA level. Always make sure you keep your chlorine level within the suggested range or else you risk an algae bloom.
BTW -- Welcome to the Pool Forum!
