Results 11 to 15 of 15
Thread: startup chemicals
    Default Re: startup chemicals
    You need to continue adding borax till you get a pH above 6.8!
    Jul 2011
    Ga.
    I have not added any borax. How much should I start with?
    Thanks!
    Not knowing your alk, I would start with a couple of cups, poured slowly into the skimmer, breaking up any clumps. Let it circulate for a couple of hours and retest, adding more if needed. If two cups didn't move it, then try 4 more. You're aiming for a pH between 7.0 and 7.8.
    1/2 box, added directly to the skimmer if you have one -- slowly, with the pump running!
    Otherwise, broadcast it around the pool. Any lumps may take a day to dissolve, unless you get in and smush them.
    Test after 4 hours of circulation, and repeat as needed. Raise your pH to at least 7.2
    Argh, simul-posting again!
  1. SWG startup
    By rockpoolmike in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 08-30-2006, 04:11 PM
  2. SWG startup
    By rockpoolmike in forum Testing and Adjusting Pool Water Chemistry
  3. Help on startup
    By jawman in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-17-2006, 12:06 PM
  4. PH way low on new startup - need help
    By Nevets in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-28-2006, 08:08 PM
  5. My Own Startup.
    By CarlD in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 04-18-2006, 11:30 AM
