Thread: brown pool water
    Jul 2011
    Default brown pool water
    We just filled our pool (using well water) added the chemicals as directed and the water turned horribly brown. Is there a quick/cheap fix for this or is it better to drain the pool and have water hauled in
    Default Re: brown pool water
    Hi mybus10 and welcome to the forum! We have had so many people this year on the forum with well water it is unbelievable! Is this a brand new pool? What kind of pool is it and what is the volume? Clearing it up is not quick nor easy. *If* having water trucked in is an option and not ridiculously expensive, that might be the fastest fix. But, make sure the source of water that will be trucked in is not well water!
    Hi MyBus;
    I notice you haven't checked back since posting, so let me know when you are ready for some info.
    But, if you'll read through the other posts in the section I'm moving your post to, you'll see many discussions of similar problems. If you need specific help, please do tell us how you are testing your water, and what sort of chemicals you've been using.
    Ben
  1. brown pool water
    By tlwilliams05 in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 07-03-2011, 11:47 PM
  2. brown water from well in pool
    By Hanna in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 05-04-2011, 08:13 AM
  3. Brown water in pool- from Iron
    By newguyjosh in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 07-11-2010, 12:22 PM
  4. Brown Pool Water...please help
    By AndyGuthridge in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-26-2006, 12:05 PM
  5. New pool, brown water
    By diwilson in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-12-2006, 02:24 PM
