If you maintain the pool, it's indefinite, but you may need to resurface it as often as every 5 years. Installing a gunite pool is definitely more expensive than a vinyl liner, which, with care, can last 15 - 20 years. However, one thing you can count on: No matter what you do, sooner or later you will need to replace the liner. That's not true of gunite--only if you don't care for it properly.
A gunite pool also requires you to monitor and adjust the calcium content of the water so it doesn't leech out of the walls. And total alkalinity is much more sensitive than vinyl. When new pools or new surfaces cure, people find themselves fighting very alkaline (high pH ) pools
If your dog likes to swim and you want him to, go with gunite, shotcrete, pebbletec, tile, plaster, etc. Dogs tear liners, frequently.
Vinyl doesn't tolerate excessive acidity or excessive chlorine well. Gunite does. However, vinyl doesn't care if calcium is low or high and can run perfectly well with too high or too low Total Alkalinity levels (I'm now running about 25% below the minimum "recommended" Tot Alk level and my pH hasn't moved in 7 weeks).
Then you'll want to know about pumps and filters.....![]()
