Need to replace I/G liner and coping....
we are planning to replace our liner next season and will need to have the coping replaced as well sue to several cracks (advised new liner will slip out as the old one does if not replaced). Does anyone know what this involves and approx cost? Also does anyone know if it is possible to have stairs added to shallow end when new liner is installed..how would that be done? thanks
Re: Need to replace I/G liner and coping....
I don't have the knowledge others do on here, but I did get an estimate on a new liner the other day. Approx. $5000!! Breakdown: We have a 20x40 IG pool with walk in steps. I guess it can be more technical cutting the steps out? Meaning cutting the liner to go around the steps. Liner approx. $2500, install, approx.: $1500. We would need two truckloads of water to just hold the liner for the steps to be cut out? The going rate for that is: $500. I know good luck, we are in the same situation, without any resources to replace at this time or no time soon! I didn't even mention these figures to my husband as he is already feeling down, smile...someone has to!
