Re: Cloudy Water
You need to shock the pool, as Watermom posted above, and keep it at shock level (12 ppm for your pool with no CYA) until the pool clears up, with pump/filter running 24/7. Your other numbers all look pretty good, except for the CYA, which you need to add, if you haven't already. Follow the label directions to target about 40 ppm of CYA, and either add it slowly through the skimmer (but you can't clean/backwash the filter for several days after the addition because it takes awhile to dissolve) or put it in an old sock and tie it in front of the return until it dissolves. Since you're going to be filtering out what is probably algae and needing to clean your filter, I would go with the old sock method.
