Results 1 to 10 of 51
Thread: Using a Nature 2 system with the BBB method
    Default Re: Using a Nature 2 system with the BBB method
    My bad!
    I'm sorry, I was confusing the S244T with the older bolted Hayward filter. Forget all the stupid stuff I said about that; I should have checked the model number. You still need to check the sand, but will -- as you knew -- have to cut pipes to check the sand in a top-mount filter like yours.
    Jul 2011
    Chattanooga, TN
    I opened the filter. What a mess. There was a huge channel from top to bottom 6-8" wide. Some of the sand was very hardened. No wonder no filtering was taking place. So now there is new sand, and the plumbing has couplers in it.
    Pump will be running 24/7 for a while. In a day or two I hope to see marked improvement.
    1994 Sun Pools Fiberglass in ground 20,000 gallon pool - Nature 2 purifying system
    Wood stove heater - Stainless steel liner - Hayward 3/4 hp impeller super pump and S-244T 62GPM sand filter
    Just FYI; often bad sand means you've been using things the pool store sold you that you would have been better off leaving in the pool store!
    Jul 2011
    Chattanooga, TN
    yes, in my case, 17 years of junk sold by the the pool company. I know better now. I'll let you know how the filtering goes now that the filter is working correctly.
    Good luck!
    Jul 2011
    Chattanooga, TN
    Overnight has made a big improvement! I suspect it will take several days of filtering, vacuuming, brushing, etc., but real progress is being made!
    Great!
