Thread: Wood Stove heater
    Jul 2011
    Chattanooga, TN
    Default Wood Stove heater
    Question 1: What additional chemical issues might I have to worry about due to the fact that I heat my pool to 98-101 in the winter with a wood stove that has a stainless steel jacket through which the pool water circulates? The plumbing is PVC except for a few feet of iron pipes and fittings in the back of the heater.
    As per my signature line below, I have an in-ground, 15 year old, 20,000 fiberglass pool that uses a Nature 2 cartridge to sanitize the water and keep the algae down. For years I had no problems. Then 2 years ago the hot winter water turned dark - Local pool stores couldn't find anything in the water... OK it eventually cleared up, so it is not my current question. My question is the preventative, educational one posed above.
    1994 Sun Pools Fiberglass in ground 20,000 gallon pool - Nature 2 purifying system
    Wood stove heater - Stainless steel liner - Hayward 3/4 hp impeller super pump and S-244T 62GPM sand filter
