Thread: Sand Filter Question
    waldreps is offline Registered+ Thread Analyst waldreps 0
    Lake Park, MN, USA.
    Default Sand Filter Question
    Does anyone know how many pounds of sand an old Pac-Fab PF-50 sand filter holds? I'm thinking it is 200lbs but I can't find it anywhere on the internet. I can find parts and schematics but not the specifications. Thanks.
    Scottsdale, Arizona
    Default Re: Sand Filter Question
    200lbs sounds about right .... You might want to contact poolsupplyworld.com and ask .. they are very helpful and sell Pentair products.
    Lake Park, MN, USA.
    Thanks for the reply....I just got back from the local pool store. They knew and 200lbs is correct. I bought my sand for $8.95 per 50lb bag from them and two used laterals for $5 for the pair. I had two that had a crack in them. All the old, yucky sand is history, and I should be running sometime tonight.
