Thread: Calcium Hypochlorite Granular Chlorine vs Bleach
    Jul 2011
    texas
    Default Re: Calcium Hypochlorite Granular Chlorine vs Bleach
    I just did some rough calculations, which seems to me to be off. I came up with about an 8:1 ratio needed if using bleach (6%) instead of calcium hypochlorite. (48%) (?) This may be in error bit I got that approx. ratio by experimenting with the "Pool Calculator."
    If bleach is .0156 per ounce (by volume) and hypochlorite is .21 per oz., then bleach is approx. half the cost. Doesn't seem right.
    In addition to being cheaper, bleach doesn't add anything unwanted to your pool like Cal-hypo does. Bleach breaks down into chlorine and salt water. Cal-hypo breaks down into chlorine and calcium, which is fine for awhile and is actually needed in concrete/plaster pools, but can cause milky water problems as Watermom mentioned above when the levels get too high.
    Jul 2011
    texas
    I understand the benefit of using bleach but I find it hard to believe it's half the cost. I was waiting for someone to correct my math though.
    In this old thread I compare the cost of chlorine sources. The prices are old (and Ben, please fix whatever broke with "code" blocks), but basically bleach and Cal-Hypo aren't that different in price, bleach being a little cheaper. In some areas of the country, Cal-Hypo is cheaper than bleach. I think you are getting your factor of 1.7 price ratio because you are using a higher price for Cal-Hypo than one can get if one buys in quantity. Nevertheless, bleach at a good price is usually the least expensive source of chlorine (other than chlorine gas you can't get).
