Results 1 to 3 of 3
Thread: TA or Adjusted TA
    Jun 2011
    Central Texas
    Default TA or Adjusted TA
    In using the K 2006 test kit the guide talks about using cyanuric acid correction to total alkalinity. When we post test results do you need the total alkalinity to be adjusted or just as tested?
    15,000 gallon gunite pool
    Sand filter
    1.5 HP pump
    waterbear's Avatar
    St. Augustine, Fl
    Default Re: TA or Adjusted TA
    The TA adjustment works out to be about 1/4 to 1/3 the CYA meaurement (depending on pH) so unless your CYA is well above 100 ppm the difference in TA readings between the adjusted and raw will usually be LESS than the precision of the test itself or, at worst, about 10 ppm off.
  1. Adjusted? Total ALk?
    By CoffeeBean in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-18-2006, 02:35 PM
  2. Calculating Adjusted TA due to high levels of CYA
    By nicole12 in forum Dealing with Alkalinity and Calcium
    Last Post: 07-01-2006, 07:25 PM
  3. Total Alkalinity and Adjusted Total Alkalinity
    By cheshamjim in forum Dealing with Alkalinity and Calcium
    Last Post: 06-18-2006, 09:36 PM
