Results 1 to 3 of 3
Thread: Test Kit Purchase
    Jul 2011
    Corinth, MS
    Default Test Kit Purchase
    I read a couple days ago from a moderator who recommended a particular Amazon vendor due to substitution issues. Don't remember the specifics tho. I just went to amazon thru your link and VM Innovations showed up for the supplier of the K-2006. OK, or wait for another vendor? Also, will a small kit last the season or do I need the 2 oz kit. I like what someone posted about buying fresh reagents each spring.
    18x36 vinyl liner, 16,500 gal, non-diving. Hayward 1.5hp 2-speed pump w/StarClear Cartridge filter 120sf
    Default Re: Test Kit Purchase
    You want to order when the seller is Amato Industries. I just checked the links and today they must be sold out because they are not listed as the seller for the K-2006 or the 2006C either. Wait a day and try again. They seem to restock very quickly -- at least that has been the case all summer. Try the links again tomorrow. Some of the other sellers are sending the K-2005 which you do NOT want.
    The smaller kit will do fine for the season unless you have very high CYA and a green pool and are having to shock very high as a result. That isn't the case for you since you have a fresh fill. But, if you go ahead and get the 2006C, it is actually a better deal and if stored in a cool place, it will be fine for next year as well. I have kept kits for several years and the reagents have been just fine.
    Albatross,
    We were just informed this morning that the Amato Industries website is down. Ben talked to them this morning and they DO have kits in stock, but we'll have to order them by phone until their website is back up. Their phone number is 800-992-6286.
  1. have to purchase a new liner and need help!
    By lne216 in forum Above-Ground Pool Construction & Repair
    Last Post: 05-11-2013, 06:14 PM
  2. Heater Purchase Advice
    By ericzlot in forum Pool Equipment & Operations
    Last Post: 01-11-2012, 10:50 PM
  3. Anyone purchase from aquapoolstore.com?
    By GreenLight in forum Pool Equipment & Operations
    Last Post: 05-13-2006, 12:16 PM
  4. Where to purchase a SWG
    By donfranko in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-07-2006, 12:31 AM
