Results 11 to 14 of 14
Thread: Polyquat dosage?
    Default Re: Polyquat dosage?
    Quote Originally Posted by HappyWino View Post
    although the Amazon links in your sig seems to just go to the Taylor website which has it's own order/cart pages?
    That's weird. I just checked the link and it went to Amazon where it listed Amato Industries as the seller (which is good since their website has been down for a day or two.) At any rate, when you click the link and get to Amazon, from there you can search for other products and navigage away from the test kit page. And, anything that is bought earns the forum a little $$$$.
    Jul 2011
    I see what is going on, I get a different result in Chrome (my "normal" browser) and IE, IE renders the graphic and the amazon button, Chrome (at least on my computer) doesn't.
    Hope that helps
    HW
    15k gallon above ground plaster pool | 300 sq ft cartridge filter |BBB + trichlor
    I've been experimenting with alternative Amazon links, and seem to have found a pattern that works, and that I can use directly on the forum. I'll have to get cracking on that.
    Ben
  1. Initial DE dosage on green pool startup
    By Water_man in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 09-06-2012, 06:13 PM
  2. Calculating dosage for borax and dichlor powder for Intex easy set pool
    By swimg in forum Pool Chemistry for Intex-type Pools
    Last Post: 08-11-2012, 11:53 PM
  3. Breakpoint chlorination dosage for indoor pool, please1
    By James Ma in forum Pool Chemicals & Pool Water Problems
    Last Post: 08-11-2012, 11:50 PM
  4. Plan on closing today, but read about polyquat dosage prior to closing...
    By The Raddish in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-06-2006, 10:50 PM
  5. 40% Polyquat
    By jonv112 in forum The China Shop
    Last Post: 10-02-2006, 08:11 PM
