I picked up an Algae bloom (I think)
So up until last week the water was perfectly clear, I did notice the bottom felt slick, so it did cross my mind, but the numbers had been hold fine. Then the water began to get cloudy. I took new readings, had lower CL. I also found I had no CYA (?!). Prior to this I had added stabilizer and had a solid 40 reading. Nonetheless I had cloudy water and no CYA, so here I started with:
FC - 0
pH - 7.4
CYA - 0
Alk - 120
I began adding bleach (then switched to granular cal hypo) pushing my Cl to above 12. It's been four days and there has been no change in the water. What should I be doing?
thanks, herb
25 gal inground
gunite pool
