pool automation
I have been maintainig my own pool for a number of years. I am looking for advice as to how to make it more energy efficient.
20,000 gallon pool with coverstar cover
I have a 3/4 hp main pump 220v runs 24/7
polaris booster pump 220v on timer.
heater on 24/7 to maintain temp
offline hayward chlorine dispenser.
Issues:
Main pump must be on when polaris booster is on.
Main pump must be on for the heater to maintain temp.
If main pump shuts off before heater-- heater clanks.
If main pump is off water temp may take too long to heat up again.
Can anyone recommend a way to minimize the electricity cost through a system that would sense temperature and run main pump as needed and still maintain temp, shutting of only after heater is off and cooled by water flow and turning on the polaris only when the main pump is on? To confuse mattters I am considering a salt chlorine generator that would need the pump to run as well.
Is there a computer system that takes all these factors into account? would I be better of constantly runnig the main pump but with a variable speed?
Thanks,
And sorry if this sound a bit confusing.
- You may not post replies
- You may not edit your posts
Forum Rules
