Results 1 to 8 of 8
Thread: Foam in Weir
    Jul 2011
    Default Foam in Weir
    I came looking for info....wondering if I can replace the foam in the weir rather than purchasing a whole new door/flap. It is flaking and looks like the foam would just slide out if I knew the type to replace it with.
    Jul 2011
    Default Re: Foam in Weir
    The part is....Hayward Skimmer Weir SPX1091K1.
    I would like to know what type of foam (or viable alternative) is used in a weir so I can replace the foam and not the whole door.
    Thanks.
    It's often polyethylene, but I've no idea where you could get it in the right thickness, or a find a glue to attach it.
    Why don't you want to replace the whole door? It will almost certainly cost more to buy a sheet of foam and appropriate glue . . . even if you can find it.
    Jul 2011
    Thank you, I guess I'll probably end up having to do that.
    I didn't want to replace the whole door because the whole door doesn't need replacing.
    It looked simple enough to replace the small piece of foam in the door.
    I will have to order it online and that means 15.00 plus 13.00 shipping.
    I thought that extravagant for a 5 inch piece of foam that perhaps could be replaced with an alternative that is available at maybe a craft store or boat store if I was only savvy to it.
    It sounds like an admirable project. It's very hard to glue polyethylene. If you find out how they do it -- I don't know! -- and find inexpensive sources for both the glue and the foam, I'm sure others would be interested.
