Results 1 to 10 of 10
Thread: Lowering TA.
    Dec 2005
    Jupiter, Fl.
    Default Re: Lowering TA.
    Thanks Waterbear. I read this advice from you some time ago and thought, oh no, I could never do that! That said, I think I have l have gained enough knowledge on here since then to have the confidence to try this. I will top off the borates, CYA et al and then add the bleach the night before we leave. I will let you know how it goes. This will probably be a perfect opportunity to soak my carts for two weeks as well.
    I live in South Florida. I have owned my first pool for 6 years now. 12,200 gal. with exposed aggregate finish, spa with spill over, cartridge filter, pop up bottom cleaning jets, Chlorine by swg. I am eternally grateful for The Pool Forum!!
    15'x30' Rectangle w/ ovals at ends 12.2K gal IG pool; Bleach now as SWCG died.; Hayward 1200 cartridge filter; Emerson 2HP pump; 6hrs; Taylor K-2006 La Motte Borate Test Strips; utility; summer: ; winter: ; iPad; PF:9.8
    soaking the carts for 2 weeks is a bit excessive. Remember that the degreasing solution (TSP or dishwasher detergent) is somewhat caustic and the extended soaking might be potentially damaging. If you are using a commercial acid cartridge cleaner a two week soak is definitely damaging.
    Dec 2005
    Jupiter, Fl.
    I use electric dishwasher detergent. I have let them soak that long before and not had any problems to this point. Before I found The Forum I used to throw them out after a year! What a waste, I wish I had those back. Live and learn. Thanks again Evan!
    YOu can shorten the life of the bands and end caps with such an extended soak.
