Results 11 to 15 of 15
Thread: New Here. Going to Salt???
    Largo, Florida
    Default Re: New Here. Going to Salt???
    Quote Originally Posted by famousdavis View Post
    One other thought. The Jandy user manual says the controller is supposed to be installed a minimum of 5' off the ground. The electrian who installed my Jandy SWCG put the controller only 3' off the ground. Not sure why that matters, really, except that being lower to the ground, there's a greater chance of having rain water hit the controller, or having my lawn's sprinkler system hit the controller. When you have them do the install, be sure to tell them you want the controller installed 5' off the ground.
    I believe Rain/Sprinkler moisture and of course dirt are the main reasons to keep your electrical higher off the ground. In some areas the electrical codes require them to be a certain height. You should check with your city/county and see if there are any rules about it.
    Round Rock, Texas, USA.
    Quote Originally Posted by SargeRmb View Post
    I've been a slave to the pool store for three years. I have a 29,000 gallon inground pool. Im using Nature 2 . I like the idea of the salt system keeping a steady chlorine level but the cost upfront is going to hurt a little. I am looking at the Zodiak Jandy Aqua Pure Ei. Im not finding a ton of info on them good or bad. Please go easy Ive got lots of questions. Thanks
    I would hesitate before going to salt. Maybe embrace BBB, and pour liquid bleach for the rest of the season. Get a good test kit, and learn the pool chemistry needs as you wean yourself from the pool store. A typical pool owner linked to pool store advice will have run away CYA by this time of the season, that is if the primary means of chlorination is Tri-Chlor tablets. If this is the case, a partial drain and refill might be required before you get control of your pool.
    Before going to salt, there needs to be a checklist of prerequisites to consider. This include: pool type, local climate (low average rainfall is bad for salt pools), pool grounding (any electrical currents flowing now between pool parts, i.e. pump, filter, heater, pool rebar, house ground, will be much worse with salt - galvanic corrosion), any metal in the water may corrode, etc. Also some heaters might cap the TDS which exclude salt systems.
    Another issue with salt has to do with filter backflushing. Before switching to salt you can usually backflush into the grass. Afterward with salt the backflush will kill the grass. So what do you do? Backflushing in the street leaves a mess (IF DE) which might upset your neighbors, and discharging into the city sewer might be illegal depending on where you live.
    Depending on your fill water properties, keeping the water TA (total alkalinity) < 100 ppm might require lots of acid every month. If the TA cannot be controller, then the PH will quickly and constantly rise to > 8.
    Bottom line, don't drink the pool store Kool-Aid. Switching to salt has its own set of issues just like the other methods. Sometimes switching to salt might not be practical.
    Jim
    Ft Lauderdale, Fl
    There's no specific code calling for 5' above ground. It's got to be 10' from the edge of the pool (for 110' volts) or 5' (220 volts), according to NEC guidelines.
    I agree with not putting the controller indoor. Some will use a quick disconnect connection, rather than hard wired, so that they can remove and take the equipment indoor during the winter months.
    Keep in mind that all equipment are designed for outdoor locations, but for winter snow and thaw conditions, at type of exposure would call for the need to remove and put the equipment indoor.
    Sean Assam
    BigDave's Avatar
    I'm pretty sure the NEC 1999 permits placement of a recptacle for pump / circulationbetween 5' and 10' of the inner wall of the pool regardless of the voltage. As always, check with you local construction official.
    drband's Avatar
    drband is offline Lifetime Member Thread Analyst drband 0
    Gainesville, GA
    You COULD just go to an added salt pool and continue w/ BBB. The water feels better (opinion) and once you get BBB going well, your pool will reach a sort of equilibrium so that adjustments are usually minimal and you will have fewer problems keeping it balanced and sanitized. SWCG pools are not any cheaper to maintain, but may be slightly easier to keep balanced. If cost is a big factor, I would recommend sticking with regular BBB and just adding salt. You don't really need the nature2 to run a BBB pool and that is an expense you could leave off.
    10,000 gallon IG vinyl liner pool, BBB user, salt added to 2300 ppm (because it makes the water feel great!), new liner/new water on 6/23/11, algae-free since 2006 (at least that's as far back as I remember). 1HP Hayward 2-SPEED CONVERTED Superpump, Hayward sand filter, PS234 test kit.
    Goal: To remain completely algae-free for the life of this new liner!
    Life lesson: It is what it is.
    12'x24' oval 9K gal IG pool; bleach; Hayward 244T sand filter; Hayward Super pump, 1 HP, 2-speed pump; 24hrs on low speedhrs; PS234; utility water; summer: ; winter: ; android phone; PF:13
  1. Salt water system faulting high salt.
    By Skelly607 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-27-2013, 10:43 AM
  2. Aqua Rite low salt reading when salt has been tested high
    By DirtRider67 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 08-19-2011, 05:58 PM
  3. Salt Level Keeps High without Addition of Any Salt
    By TooSalty in forum The China Shop
    Last Post: 08-13-2011, 01:56 PM
  4. Salt in a Non-Salt Water pool
    By wollypog6 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-31-2006, 10:01 AM
