Results 11 to 12 of 12
Thread: Question about hardness test
    Katy, TX
    Default
    Mmmmmmk. Only thing is, I've been tested for both Fe and Cu, both showed negative. I still get the funky clumping and semi-solid colorchange. I'm not sure if that's the only thing at work here? *shrug*
    Michael
    Exclamation
    the other factor, as I stated in an earlier post, is to swirl the test vial for 30 seconds between drops of the titrant and to really give it a good swirl (up to a minute) when you add the indicator (reagent 2). The ideal way would be to use a magnetic stirrer and a beaker when you do the titration like some of the pool stores do. This test can take a while to do if you do it right. Rushing it can cause all kinds of problems (a lesson I learned from my years of keeping saltwater reef tanks!)
    Also, reagent 1 is what removed the magnesium interference so make sure the 20 drops are well mixed before adding the indicator!
  1. Taylor calcium hardness test
    By carp6318 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 12-28-2011, 12:10 PM
  2. Replies: 5
    Last Post: 12-04-2007, 11:22 PM
  3. Oxone and Calcium Hardness Test
    By Pool in Carolina Blue in forum DPD-FAS based testing
    Last Post: 05-29-2007, 01:23 PM
  4. hardness test with hth kit
    By poolgal in forum Dealing with Alkalinity and Calcium
    Last Post: 07-09-2006, 11:07 PM
  5. Test for total hardness
    By elyders in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-05-2006, 01:42 PM
