If you have a cheap OTO kit (yellow and red drops) you can use it til you get your refills. It will only read to 3 or 5 but you can force it to read higher with a dilution method described here: Testing Without a Good Kit
sounds like a plan but i would have to dilute it like 10:1. its a 6mm vile and ive done 1mm pool water to 5mm distilled and still not high enough to reach 300ppm. how do i do even more. thanks
I'm confused...and hoping the 300 ppm was a typo and you meant 30? If to, use 1:6 ratio and multiply by 7. You're losing some accuracy with each dilution, so you're actually getting a ballpark....
yes, 30ppm sorry.
I had enough regeant for 2 more tests. last night
FF 29ppm
CC .5-1
This mourning
FF 24ppm
CC .5-1
my wife is starting to question all this. As i said before, the pool was clear, never had algae visable on pool surfaces to where i need to scrub. Only milky or cloudy water. Ive read these great responses over and over but someone needs to tell me why this is taking so long. going on day 4.
By the way i have lowered PH and am currenty aerating to lower TA before i add borax. thanks for any comments
sorry FF last not was 27ppm
And my TA went from 200 to 250. How the heck did that happen while I was aerating?
I cannot explain why the big change in TA.
Hang in there with the high chlorine. I know it gets frustrating but you'll win. 4 days isn't all that long to fight the water when something is brewing.
Hey Shub;
Some of the contributors and I have been discussing high Cl + high CYA operation, and there is a better method for testing pH for you. You'll need a gallon of distilled water, a measuring cup, and your pH kit. Simply mix pool water 1:2 with distilled water: 1/4 pool water & 1/2 cup distilled water in a glass measuring cup, stir, and test.
You don't report pH (for obvious reasons) but I'm guessing your pH had climbed quite a bit, which affects measured alkalinity levels in its turn. If you keep lowering pH to below 7.0, and then letting it rise before lowering again, you will lower your TA over time.
Regarding chlorine consumption - it may, or may not be unusual to lose 5 ppm per day.
However, cloudy water in the AM after a clear PM, has always -- in my experience with commercial pools -- been associated with either incipient algae (rarely) or heavy bather load (lotion, urine, sweat) with inadequate chlorination.
So let me ask some more questions and clarifications:
+ your pool is about 17K gallons
+ you mention lots of kids on the deck: how many users in the pool daily?
+ are your users heavy users of lotion or sunscreen?
+ do you have any 'slip and dippers' -- ie, lotion up, lay out, rinse off, repeat ? (This creates heavy chlorine demand.)
+ is your pool a long way from the bathroom and / or have you forbidden wet swimmers in the house? (= pees in the pool)
+ are any of your users competitive swimmers? (USS swimmers are accustomed to pee in the pool. Really. It's universal.)
+ is your pump on a timer? What are the settings?
