Thread: Pool newbie
    Jul 2011
    Florida
    Default Pool newbie
    Hi Everyone :-D
    Myself and the wife recently bought our new ( to us ) home and it came with a pool. We have thus far understood the basics of maintaining the chemical balances, every week we get the water checked out and it comes out fine so far.
    My newbie question is that I do not quite understand what all the valves are near my pool pump. I only know what the main tank does in respect of cleaning filtering and back washing. Our pool consists of 6 jets one of which doesnt work, a waterfall and two skimmers.
    Below are some pictures of what the pool pump looks like, I would be most grateful if you could advise me on what all these valves do? The pool was heated via solar at one point, that is all I know.
    When I turn the black valve near the basket the pool pump starts to make a high pitched noise, as if it is loosing prime so I put it back to original setting, the water in the basket also appears to go down when I turn this dial.
    I am unsure what the red valve on the wall is , when I turn it I can hear water traveling through them pipes, however again I put it back to original setting.
    The other area of uncertainty is the object called the chlorinater , unsure if maybe this was once salt water based perhaps?
    Sta-Rite skimmer with a winterizing plug still in place:
    Pool pump, filter, and piping with 'train-wreck' pipe layout
    Suction side piping, probably with 1 pipe from skimmer and 1 from the main drain.
    Note the 'train-wreck' layout - see comments below.
    Pressure or return side piping, with reverse train-wreck layout.
    Old Sta-Rite pump, strainer basket lid view.
    Jandy type valve
    Abandoned loop for solar heating panels?
    If those are spring check valves, that loop is a MAJOR flow restriction.
    Rainbow 320 trichlor feeder on return piping.
    Bold green = PoolDoc notes on photos
    Default Re: Pool newbie
    I just labeled the photos in-line.
    There are two significant flow restrictions on your piping. The first is the 'train-wreck' piping, typical of Jandy valve layouts, which sets up two opposing streams of flow in a collision or 'train-wreck' layout. It's not so bad when the flow come from the 'stem' of the tee, rather than the arms. This is the case on the return piping. But, it's quite bad when the flow is coming from the arms and exiting out the 'stem'.
    In fact, it's SO bad I've never been able to find a pressure drop table on such a layout, in either pool or plumbing tech literature. I guess the engineers assumed that anyone with enough sense to use such tables would have enough sense to avoid such a layout.
    The second flow issue is the check valves on the loop on the wall. Valves like these sometimes have springs in them, that can result in enormous flow losses.
    If the loop serves no purpose, it might be best to remove it.
    drband's Avatar
    drband is offline Lifetime Member Thread Analyst drband 0
    Gainesville, GA
    Shouldn't the winterizing plug be removed from the skimmer? Then you could actually use the skimmer! Glad Ben could decipher that plumbing layout... it's not obvious- at least to me.
    10,000 gallon IG vinyl liner pool, BBB user, salt added to 2300 ppm (because it makes the water feel great!), new liner/new water on 6/23/11, algae-free since 2006 (at least that's as far back as I remember). 1HP Hayward 2-SPEED CONVERTED Superpump, Hayward sand filter, PS234 test kit.
    Goal: To remain completely algae-free for the life of this new liner!
    Life lesson: It is what it is.
    12'x24' oval 9K gal IG pool; bleach; Hayward 244T sand filter; Hayward Super pump, 1 HP, 2-speed pump; 24hrs on low speedhrs; PS234; utility water; summer: ; winter: ; android phone; PF:13
    Jul 2011
    Florida
    Thanks for your responses, much appreciated. The previous owner did indeed have a solar panel once, this was removed once he re-roofed the house. The red valve on the wall, I can turn it however and can hear water flow but unsure as to what purpose it serves so I always turn it back to its original state.
    Both skimmers have this white plug screwed into them, I notice you stated it was for winterizing. So in essence if I remove each white plug from each skimmer what advantages would it give me? Both skimmers have two holes and both skimmers have one white plug screwed into them.
    Also when I move the below valve to the opposite direction the water in the basket goes down and the pool starts to loose prime I think the pressure guage goes down and it makes a high pitched noise. When turning this valve all skimmer shut off, I am assuming it is directing flow to main drain?
    Typically, a valve like that has a gate that is positioned opposite the handle, so that the port the handle points to is closed. If this is correct, and you move the handle 180 degrees from the position shown, you'll close all flow to the pump.
    Regarding the solar loop, currently it appears 100% of your water flow goes through that loop, so closing the valve would (again) stop all flow.
    . . . I think you need to hire a pool service guy to come out and show you how to operate your pool. You aren't likely to get very good results trying to work it out here.
    Jul 2011
    Florida
    True, was thinking the same also. Getting someone to show me.
    Jul 2011
    Florida
    Wow, I was searching online for certain pool issues and came across my own post from 6 years ago.
    I'll update shortly with new images and of course another set of issues LOL
  1. Pool Newbie
    By warren_tax in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-18-2012, 05:15 PM
  2. Newbie needs help with pool closing
    By ReelNut in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-10-2010, 09:10 AM
  3. I am a newbie here and with pool
    By raptureready1953 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-02-2006, 03:44 PM
  4. Newbie with a Fox Pool...
    By mariner09 in forum Pool Equipment & Operations
    Last Post: 06-13-2006, 12:08 PM
