Thread: Pentair check valve/divertor
    Mahwah, NJ, USA.
    Default Pentair check valve/divertor
    Does anyone have a suggestion for a temporary solution to stop a damaged check valve/ divertor from leaking? Lost about a foot of water last night checking damaged part (Pentair part # 263042z). Replacement coming from Amazon tomorrow.
    Flap on part was covered in what looked like deteriorating white rubber. Same thing happened a year ago and I'm told this part should last longer. Thanks.
    NJ Pool: In Ground, 40,000 Gal vinyl liner, chlorinated using BBB, Gas Heated, DE Grid filtration.
    FL Pool: 10K gal gunite, chlorinated with 3'' pucks, cartridge filter, spill over spa
    swimdaddy is offline *Removed User* Weir Watcher swimdaddy 0
    May 2014
    Washington state, east
    Default Re: Pentair check valve/divertor
    Sorry no one got to you. Did you get your part? Did you figure out how to stop the check valve?
    Mahwah, NJ, USA.
    I got the replacement part from amazon with expedited shipping and everything is fine again. I could not figure out a temporary fix to prevent the water from draining so had to continually re-fill to prevent the pump from sucking air. I have an infinity edge with auto refill but if the pool gets too low overnight the basin drains faster than the auto fill can replenish. Might purchase a spare valve in a few years to keep on hand, I'd estimate life expectency to be less than 10 years so I have some time to think about it.
    Scottsdale, Arizona
    It's ok to turn your pump off for a couple days if you need too.
