Results 1 to 10 of 18
Thread: Patching a leak in a vinyl liner
    Virginia
    Default How to patch???
    Hopefully someone will see this post in this old thread.....
    I found a very small tear in my liner and ordered the suggested Boxer patch kit to repair it. The included clear vinyl patch has a smooth side and a textured side, but the instructions don't say which on side to apply the adhesive.
    Anyone know? My guess is the smooth side for maximum surface contact with the glue? Or the textured side to give the glue something to grip to? I don't know......but I'd like to get this right the first time.
    Help!
    Edit: I found an FAQ for Boxer Adhesives:
    http://www.boxeradhesives.com/faq.html#11
    According to the FAQ it makes no difference which side is used. . I think I'll apply glue to the textured side so smooth side is exposed to water (don't want to give algae/gunk anything to cling to ).
    Default Re: How to patch???
    If your pool wall is smooth, use the smooth side. I saved a bunch of vinyl from my old liner and use that to patch my current (now doomed) liner. I like to double-patch: The first patch is about 1/2" - 1" bigger than the hole. The second patch is at least an inch bigger than the first patch.
    Virginia
    I do have pieces of the original liner, but it's thicker than the clear patch and I'm thinking the thicker/white edges will be more obvious and easier for something to catch on and pull off the patch.
    Out of curiosity, I did a leak test where I found the small tear (it's very small; hard to see but can feel it with my finger). I didn't notice any dye (actuall I just used phenol red) being sucked in. Perhaps the tear doesn't penetrate the liner?
    While I was checking for a leak, I also checked around the steps and fixtures.....nothing noticeable. The past two winters I lost about 4" over a period of about 7 months (pool coved with a solid cover), so there's a leak somewhere, but I can't find where. I'm not too concerned about it right now since it's such a slow leak. It's not noticeable during the swim season.
    If you get the outer patch sealed properly (I use a rubber tile roller) it will be FINE and last for years. I've tried other patching materials, but the Boxer glue and liner material, double-patched, make the BEST and most durable patches. IMHO.
    Virginia
    I greatly appreciate the feedback and suggestions.
    I do need to get a set of goggles before making the repair (I don't have any). The tear is in a corner that points into the pool (lazy L shaped pool) a few inches above where it meets the floor of the shallow end. I can't quite reach the tear without dunking my head under water, so goggles would probably be a good idea. I guess cheap goggles would be good enough? Suggestions?
    Yeah, cheap goggles. If you get the glue on them (it floats and you do NOT want it on your skin or in your hair) they are probably ruined.
    Virginia
    I found an old pair of goggles in the closet, so I tried installing the patch.
    What a PITA. First attempt was a bust. The tear is just deep enough that when I submerged and tried to unfold the patch and apply it I kept floating away. Second attempt with another patch went better. I smoothed it out with a wallpaper seam roller. Looks good...we'll see how it holds up.
    Oh, and despite trying to be careful, I got glue on my hands. Looks like I'll have glue peeling off the next few days..lol
    Dye checking for leaks MUST be done with the pump off, and with you moving VERY slowly. It's almost impossible to do leak checking holding your breath, because the movement from bobbing up and down does not stop till AFTER you run out of air, and have to stir things up again.
    Last year, for the first time, I was able to use the dye successfully. I found two holes, fairly far apart where I thought there might be one. I just let the dye sit in the pool with the plumbing off and me NOT in the water, so it was still, and it found the holes.
    Virginia
    Dye checking for leaks MUST be down with the pump off, and with you moving VERY slowly. It's almost impossible to do leak checking holding your breath, because the movement from bobbing up and down does not stop till AFTER you run out of air, and have to stir things up again.
    I did shut the pump off a couple hours before trying the dye test. I also tried to move real slow. The places I tested the dye seemed to just sit there without much movement.
    I watch a few videos so I'd have an idea what to look for, but I didn't observe anything like I saw in the videos.
    At this point I'm not too worried about it since water loss over the winter was only about 1/2" per month. I don't notice any unusual loss during the summer.
    I also wonder if the leak is actually somewhere above the water line and water only leaks out when we get a heavy rain during the winter causing a lot of water to collect on the cover, causing it to sag, and displacing the water in the pool above the normal level. Btw, I don't lower the water level at closing, the idea being to help prevent the liner from floating (we're only 9ft above sea level). Plausible?
