Results 1 to 10 of 23
Thread: Brown gunk on the bottom of pool
    Lehigh Valley, PA
    Default Re: Brown gunk on the bottom of pool
    Sometimes, brown gunk is just . . . brown gunk. Our pools provide a very large surface area on which dirt collects: airborne dust particles, pollens, whatever. Not all of it gets swept into the skimmer and trapped by the filter. Much of it sinks and, in due time, makes brown gunk. I dust my furniture every so often without really giving much thought to what that fine grey layer of stuff is or where it comes from. It's just dust: dander, smoke, oils, the detritus of life inside a home.
    Since you haven't had an active algae outbreak and your numbers look pretty good and your water is otherwise clear you could just accept the brown gunk as part of having a pool that gets dirty. Not unsanitary. Just dirty. I have those same spots in mine and I would bet they're pretty common. I vacuum occasionally, I brush other times, I use a skimmer sock. The fine debris comes back, sometimes overnight, sometimes it takes a few days. I look at it as my pool's circadian rhythm
    Jun 2011
    S. Carolina
    I just didn't have any of this "brown gunk" on the bottom for about the first two months the pool was open. Then after reading on here, I started maintaining slightly higher FC levels. When I raised the FC, it was almost overnight that the gunk appeared. I had never had algae that I know of so I don't think it is algae. The water has always been sparkling clear, but the brown dusty stuff on the bottom makes the pool look nasty. Vaccuming just seems to stir it up. The pool looks spotless after vacuuming b/c you can't see the brown stuff (it mixes back in with the water) I have no way to vacuum to waste since I have a venturi type vacuum with a debris bag. It goes right through the debris bag. My filter does catch some of it before it settles back out, but no where near all of it. It will start settling again within a day. Maybe you are correct that it is just normal "stuff", it just seems odd that it seems to increase with FC levels. It sounds as though I may just have to vacuum every day to keep it stirred up. Thanks for your help Anna.
    Lehigh Valley, PA
    Quote Originally Posted by rox29160 View Post
    Each pool is unique and who knows why that brown stuff invades. You've reported clear and sparkling water and no CCs to speak of. Your pH is a smidge low but that's personal preference. It's 'in range' at any rate.
    I know those patches of brown are unsightly and it is frustrating that they come back after vacuuming and/or brushing. In my pool, it only happens during late July/early August. When it's just us here at home, I toss the dogs in to stir things up. When we expect company I might vacuum to make it all look pretty but, more then likely, I'll just let the dogs swim for a while and scoop out the fur before the guests arrive.
    Does the bottom of the pool feel squeaky clean? Not slimy? That's one of my hallmarks: a slimy feeling bottom heralds biological invaders and I might dump some extra chlorine in, regardless of what the test says. If the bottom feels clean then I'm going with Occam's Razor: sometimes, a kiss is just a kiss . . . and brown gunk is just part of the pool's life.
    Jun 2011
    S. Carolina
    Dave: Thanks, I had actually read somthing similar to that before about using batting and tube socks. I haven't actually tried it yet. I haven't figured out in my mind how to attach it to my vacuum so it works effieciently yet so I haven't tried it yet. I might just tie it on tonight and give it a go and see what it does.
    Anna: Every thing has always felt squeaky clean. Mine did show up in late July so maybe it was a coincidence that it was right after I raised my FC levels.
    South Carolina - Intex Ultra 16' x 48" (5,061 gallons), Intex Krystal Clear SWCG, Using Taylor K-2006 kit
    Jun 2011
    S. Carolina
    I made and improvised filter out of four old socks to use in combination with my venturi vacuum and debris bag. I simply put the socks, one inside the other, and tied them around the outside of the debris bag. I vacuumed all the brown stuff up a week ago and it still has not returned. (Previously, it had been coming right back after vacuuming. Most of the time within 12 hours.) The sock on the inside, the first filter if you will, was almost completely brown after vacuuming. The socks got cleaner and cleaner as you worked your way out.
    I have added 3 cups of Borax so far and let it mix in for a couple of days each time. It has changed my ph from 7.2 to maybe 7.3. I added another cup or so over the weekend and plan on checking it tonight to see where my ph is now. It seems like I am having to add an awful lot. The Pool Calculator said I only needed like 11 fl oz to raise it to 7.5. I am now at around 16 fl oz. Twelve ounces hardly made it change at all. Maybe I did something wrong on the calculator. Anybody know how much I should have to add?
    BigDave's Avatar
    Did you get alot of rain while you were trying to raise the pH? Irene maybe? My pH went from 7.5 to 7.2 in Sunday's storm. If it was the storm, yout TA probably dropped too, not that you should adjust it, just what acid does to a pool.
    Jun 2011
    S. Carolina
    I didn't get hardly any rain from Irene, but I got about 1-1/2" Monday after she was long gone, which will probably make my PH and TA worse. I had checked the PH before Irene was supposed to hit just to beat the storm. I've been dissolving the Borax in a bucket of water and then dumping it in the pool, so I don't think it is settling to the bottom or anything.
    BigDave's Avatar
    Since pH is stable, I wouldn't move the TA. I would, however, move the pH up a little with Borax, 7.2 is as low as you want to go leaving little room for it to drop. We've had alot of rain recently and my pH went from the high side of 7.4 to under 7.2 in one storm ( my TA dropped as well ). The rain consumed my margin and I was still in the safe zone - had I started at 7.2... You do have room with your TA so if you want to use Soda Ash ('cause you already have it?) then, sure, just do it a little at a time ( 1/4 cup to start ) - let it mix throughly and measure the result.
    The Brown Stuff: Does it really bother you? Is it staining your pool?
    If it is metals, you might get more when you raise the pH - watch for that. Is there more when the FC is higher?
    Perhaps your observation in the CH test is good reason to have your water tested for metals.
    Jun 2011
    S. Carolina
    Thanks for the reply BigDave. I will pick up some Borax. I've been waiting all summer for my PH to go up like the pool store lady told me it would, instead of buying something else. I knew I was on the low side. We have had a lot of rain as well, which may be the reason my TA dropped from 90 to 80 and also the reason my PH has not been increasing. I do not already have Soda Ash so it doesn't matter to me which one. I just thought my TA needed to be bumped up slightly too and Soda Ash would do both. I'll stick with Borax per your recommendation.
    The brown stuff is just a nuisance. It comes back every day after vacuuming. The water is clear but the brown stuff settles out to the bottom and makes my pool look dirty. Before anybody comes over, I have to hurry and go vaccum the pool.
    BigDave's Avatar
    I supppose it's personal preference for me. I increase TA with Baking Soda and increase pH with Borax; seems to me it's more targeted - just my thinking, either way will work. BTW, it will take twice as much (by weight) Borax as Washing Soda to have the same effect on pH.
    Swamp Mistress ( http://www.poolforum.com/pf2/showthr...-it-all!/page6 ) seems to have had luck with a series of improvised filters.
