Area Man
I have a vacuum problem that's a variation on this. I should probably replace the vacuum hose, but it can leak air at the end that connects to the vacuum adapter or plate that goes into the skimmer. When the hose moves around, a leak can open up between the hose and the hose end/connector, which is above the water line. My cheapo solution is to run water from a garden hose over this joint while I'm vacuuming. This keeps air from getting into the system and wrecking the vacuum.
Rick
