Thread: Recomended Refill Intervals
    Scottsdale, Arizona
    Default Recomended Refill Intervals
    I've heard that you should drain and refill your pool every 5 years or so... If my chemistry is balanced and the water clear and clean, is there really a need or benefit to replace it ?
    In my opinion, if it aint broke, don't fix it.
    Just curious what the opinions are among the experts
    Lehigh Valley, PA
    Default Re: Recomended Refill Intervals
    Over a period of 5 years you may well have already done that via topping it off after backwashing and replacing splash-out and evaporation.
    Pool water is sort of like the air in bicycle tires. You don't let it out and replace with fresh every so many miles, you just add a little air when they're low.
    AnnaK (by no means an expert)
