Thread: pool autofill keeps filling, overage is drained
    Jul 2011
    Texas
    Default pool autofill keeps filling, overage is drained
    Our autofill will not stop filling the pool with water. We have tried to adjust the float but that is not working. Any suggestions?
    Default Re: pool autofill keeps filling, overage is drained
    Repair the fill valve?
    Sort of depends on what you have -- if you like you can send pictures to poolforum AT gmail DOT com
    Most of them work just like a toilet tank float. It lifts till it cuts off the water, If it won't cut off when you move it manually, it's time for a new one.
