Results 1 to 10 of 33
Thread: HELP with Green/Brown Water
    Jul 2011
    Hazard, Kentucky
    Default Re: HELP with Green/Brown Water
    Thanks for the reply, i think why the water cleared so quickly was the 10lbs of iron out, because all i did before that is shock it... i didn't add any metal stuff until i returned back from vacation and the water was back to dark green. I did have the water computer tested, that is where i came up with all the number.. my dad now tells me that while we were gone they tried something called, "Green to Blue" i guess it supposed to turn pitiful green water to pretty blue.. he put it in and let it run for 4 hours or so then turned the pool off and let it sit over night, pool is clear when we do that and all the brown is on the bottom until he tried to vacuum it up and then it just mixed the dust up and got all cloudy and green again. I guess that must be some kind of floc or something... So now that we have a sand filter, should i turn it off, it's only been running for 48 hours now and it's still light green... or will it be better to keep it running and let the filter work or try and vacuum it out in the morning? i have done both in the last week, but just don't know what to do next?? So you think ihave algae now??? how is that possible with shocking the pool so much, i know before i left on vacation i shocked it like 5 times, before i went with the iron out?? then took a reading and it was so high up the charts i thought there was no way to have any algae at all...it was dark red on the chlorine reading.. i have put 4 or so ounces of algaecide in yesterday and a couple of days ago and some a few days before that also... should i add anything else to the water???? metal free?? or just let the filter work for another day or so and check it out or shut it down and try to vacuum in the morning??? this has been so aggrevating... The chlorine is already high, because i shocked it this morning again, and i just went out and put 2 trichlor tabs in the skimmer just before the sand filter to maybe help get some iron out.... WHAT ELSE TO DO, JUST WAIT???
    Jul 2011
    Hazard, Kentucky
    Just found this stuff from your forum: CuLator Metal Remover.... does this work better than metal out?? want to find something, this is killing me??
    Jul 2011
    Hazard, Kentucky
    vacuumed and backwashed this morning, still green! 2 bags of aqua shock, chlorine is probably through the roof...will be taking it computer checked in a couple hours, will post new numbers to see what i need to do, i have to be missing something.. should have a green pool with all the shock and trichlor that is in this thing..but what do i know???
    You need a good test kit so you can test for yourself and not relying on a pool store. The one we recommend is the Taylor K-2006 or 2006C (same kit, larger bottle of some reagents). If you buy it through the Amazon link in my signature, the Pool Forum makes a little money on the sale which helps us keep this form online. Only buy if the seller is Amato Industries, however. Some other sellers are substituting the K-2005 which you do NOT want. If Amato isn't listed, wait a day or two and try again. They seem to restock pretty quickly when they sell out.
    But, in the meantime, go to Walmart and pick up an OTO/Phenol Red kit (yellow and red drops) and use it until you can order a good kit. Hopefully you can find one that reads chlorine levels up to 5ppm but some only go the 3. Either way won't be high enough but you can force it to go higher by using a dilution method described here: Testing Without a Good Kit
    While at Walmart get a jug of distilled water and more bleach.
    Post with some current numbers and somebody here can help you go from there.
    Regarding the Culator --- the jury's still out on that. A few members are trying it but no definite conclusions yet.
    Jul 2011
    Hazard, Kentucky
    I will have to get a better kit, i just have cl and ph one right now... had results from computer test:
    Free Chlorine 4.8 (this is after trichlor tabs in skimmer all night, and shocking with 2 bags of aquachem shock this morning)
    TC 4.8
    ph 7.3 At least i got this right and it stays their..
    hardness 390
    Alk 27 it was 10 last week and i added 12 lbs of arm/hammer, probably need 12 more lbs
    CyA 10 Hasn't moved from last week, with all the trichlor i'm surprised....
    COPPER .42 WENT UP FROM .25 LAST WEEK, MAYBE FROM THE 3% IN THE ALGAECIDE???
    Iron .43 Still high (will this still show even if it is sequestored??) just wondering??? i have more metal out but don't know if i should put it in????
    i have 3 gallons of bleach and don't know if i should use it or metal out first or both??? HELP!!!!! Ugly green water is horrible......
    Hi Poolrookie;
    You've got more questions than we've got good answers. Once you've treated a pool with all that goop from your pool store, it becomes very hard to predict what will happen next.
    What's worse, you are in the worst of all possible pool worlds: you have both algae (which needs chlorine) and metals (which will stain if you add as much chlorine as you need) AND you've got poolstore goop in your pool, which essentially means that all the rules about what will happen next evaporate, because we can't predict how the goop will affect things.
    Anything I, or anyone else here, tells you to do will be a guess at best. It might be a good guess, but that's all. For example, your last question, about 'bleach or metal out', I can't answer. And if you do both, well bleach tends to break metal out (if it's HEDP) down.
    So here's what I think:
    + It's good you've got the sand filter; that will help.
    + You're getting a good test kit; that will be essential.
    + You have 'free' water, so dumping and draining won't cost anything.
    + If you'd started the pool the right way, you'd probably be all clear now.
    + But if you keep working with what you got, you may not get it clear before school starts back!
    So, (you can probably see where I'm going with this!) do this;
    + Use the pool as best you can, now.
    + Add some more algaecide, till the pool looks like a suds bath -- it will eventually kill the algae and it won't make the iron worse.
    + Use the trichlor, but not the bleach
    AND
    + Order your kit
    + Send me the EXACT name and brand of the "metal out", and any other chemicals you have.
    + Purchase or order 2 quarts of polyquat and 2 quarts of HEDP, if you don't already have those
    + Purchase 5# of stabilizer for your pool
    + Test your creek water, once your kit arrives, and give use the results.
    + Have your creek water tested at your pool store, and give us the iron results.
    + Get other chemicals (acid, borax, washing soda) once we've seen the fill water results.
    THEN, drain and refill your pool.
    + Do NOT add bleach while refilling.
    + Instead, add a full dose of polyquat -- 1/4 quart as soon as you start filling -- to control algae and help filter out goo, including iron
    + Fill THROUGH your circulation system, if at all possible, by putting the fill hose in your skimmer and starting the pump.
    + Add stabilizer via a sock (you'll be cleaning your filter too much to add it via the filter).
    You'll also need to:
    + Add HEDP (metal out, maybe, depending on brand) based on test results.
    + Once you have the circulation system going, add a trichlor tab
    + Gradually raise pH
    but how and when will depend on fill and test results.
    My guess would be -- and I'll be able to tell more once you tested your fill water -- that you can be clear and blue in just a few days -- with minimal added expense.
    Jul 2011
    Hazard, Kentucky
    thanks! Will probably do the best we can for another month or so and then close it up anyways....will restart from scratch next march or april....will have all the stuff to get ready for the iron and copper in the water next year definitely! will get water tested from creek, soon...will order kit too!
