It's probably a solution in search of a problem (the tool) but it just looks "cool" and I'd like to see one-- but probably would NOT spend money for it.![]()
10,000 gallon IG vinyl liner pool, BBB user, salt added to 2300 ppm (because it makes the water feel great!), new liner/new water on 6/23/11, algae-free since 2006 (at least that's as far back as I remember). 1HP Hayward 2-SPEED CONVERTED Superpump, Hayward sand filter, PS234 test kit.
Goal: To remain completely algae-free for the life of this new liner!
Life lesson: It is what it is.
12'x24' oval 9K gal IG pool; bleach; Hayward 244T sand filter; Hayward Super pump, 1 HP, 2-speed pump; 24hrs on low speedhrs; PS234; utility water; summer: ; winter: ; android phone; PF:13
Just FYI -- some pool pumps, and some installations have very poor self-priming capability. Typical methods of filling a vac hose can put enough air in these installations to be a real problem. (One of the benefits of the old-school Hayward Super Pump is that it has EXCELLENT self-priming capability.)
Hey Jim,
Did you receive the piece I mailed to you yet? I mailed it last Monday, it should be there by now.
20'x42' L' 41K gal IG vinyl pool; trichlor feeder, bleach; Pentair 420 cartridge filter; Pentair Whisperflo 1.5hp 2 speed pump; hrs; TF-100, CYA test; city;PF:2.9
Sorry Tom, I have been traveling. It actually arrived last Thursday in great shape. I will be back to the pool later this month but it looks like there won't be any issue with it working.
It was a bit alarming when I first opened the package, I have included a new drawing that demonstrates just how far off my recollection was from reality. Yikes!
The "device" is called a VacPrep and was manufactured by Plastiflex (plastiflex.com). I contacted them and was told that they stopped manufacturing the VacPrep many years ago. It does indeed have two seperate chambers as CarlD had suggested. The single shaft and opposing turbos drive water into the vacuum hose using the suction of the skimmer.
Tom, Once again many thanks for your generous assistance and passing this along.
This interweb thing sure is cool.
Jim
How long did it take you to do those drawings?
What tool did you use?
(Uh, if you wanted to make drawings of how common pool parts and components work . . . I can put them where LOTS of people will see them!)
PoolDoc / Ben
Sweet! Glad to help, keep cool.
Tom
I used 3d studio max (an autodesk product), this was a pretty simple drawing because there are very few irregular shapes and no modeling; just cylinders, rectangles and tubes, so not much time involved, the software does most of the work, including attaching the material properties (drag and drop plastic) and lighting. Also allows you to animate; probably would have taken 30 seconds to get the fan turning and maybe 15 minutes to get a convincing flow of water. The software is truly amazing in what it will do and how quickly it will do it. Downside, 3d max is fairly expensive.
For those that want a cheap entry into the world of 3d modeling go to www.Blender.org and download the latest version of Blender. It will do "everything" 3d max will do, is free, is open source and there are a ton of free tutorials and a huge user community that are constantly putting more free stuff up on the web. If you need a 3d model of a motorcycle, or fork, or birthday cake, or diving board . . . there is one out there that you will be able to bring up into Blender and either modify it or, use in a scene.
For the first timer, all this stuff will look scary at the start, but if you will dedicate an hour to reviewing the software and videos you will be surprised at how much you can do with very little experience. And I should add, no artistic talent is required, just the ability to recognize the various shapes that make up an object and scene, and a sense for proportion (although there are tools included that can assist with that as well).
Jim
uh, that sounds like artistic skill, if not talent.And I should add, no artistic talent is required, just the ability to recognize the various shapes that make up an object and scene, and a sense for proportion
Does Blender run better under Win7 or Linux?
