Re: Sand Filter and Cartridge Filter Owners Please Advise
Amati, I've been a pool owner (with a cartridge filter) for about a year now. I wouldn't say it's a nightmare at all to hose down the filter (it usually doesn't even need it, it stays pretty clean). But one thing to consider with a cartridge filter is this--are you healthy, with a good strong back? When it comes time to clean the cartridge (or at least to check it to see if it needs cleaning), you unlock and remove the top of the housing, and then you have to reach down into the housing and pull up the wet, heavy cartridge, straight up and out of the housing. And that's while you're leaning over, so you can reach down into it. I'm fairly short and it is hard on my back to do this. Aside from that one concern, the actual maintenance of it is practically nil. I pull it out and check it roughly every three or four months (I live in California, we don't have winter here, we just have summer and not-so-summer). And usually it's clean as a whistle. If it isn't, I just hose it down. I don't do any chemical soaking. It's been very low maintenance. Hope this helps.
John
15K gallon in-ground plaster pool (30yrs old) - Pentair 420 Clean & Clear Plus cartridge filter
IntelliFlo Variable Speed pump - Ray-Pac 266 BTU gas heater
