Thread: Recomended Refill Intervals
    Scottsdale, Arizona
    Default Recomended Refill Intervals
    I've heard that you should drain and refill your pool every 5 years or so... If my chemistry is balanced and the water clear and clean, is there really a need or benefit to replace it ?
    In my opinion, if it aint broke, don't fix it.
    Just curious what the opinions are among the experts
    Lehigh Valley, PA
    Default Re: Recomended Refill Intervals
    Over a period of 5 years you may well have already done that via topping it off after backwashing and replacing splash-out and evaporation.
    Pool water is sort of like the air in bicycle tires. You don't let it out and replace with fresh every so many miles, you just add a little air when they're low.
    AnnaK (by no means an expert)
  1. Running Time/Intervals for Filter/Pump?
    By TheKs in forum Intex-type Pool Setup & Operations
    Last Post: 09-12-2012, 05:49 AM
  2. Pre-Filter on a Refill?
    By Rottwieler in forum Pool Equipment & Operations
    Last Post: 06-19-2012, 05:44 PM
  3. Refill R-0871
    By BigDave in forum DPD-FAS based testing
    Last Post: 08-15-2011, 09:35 PM
  4. DE Filter Cleaning Intervals
    By Phillbo in forum Pool Equipment & Operations
    Last Post: 08-28-2010, 03:57 PM
  5. Recomended Caulking
    By Sprint54 in forum In-Ground Pool Construction and Repair
    Last Post: 04-25-2006, 09:37 AM
