Thread: Best method for cleaning debris from bottom of a spa
    Jul 2011
    Default Best method for cleaning debris from bottom of a spa
    Hey all,
    the bottom of the spa seems to routinely collect debris and I need an effective way to clean it. The Polaris 360 is too big to fit in the spa and work effectively.
    What are some good options and which of those do you recommend?
    25,000 gallon Concrete/Plaster Pool with a D.E. Filter. K-2006 Test kit. Pool Forum Rocks!
    Largo, Florida
    Default Re: Best method for cleaning debris from bottom of a spa
    I use a regular "manual" vacuum head connected to the vaccum line in my pool to clean mine. Looks like this:
    Jul 2011
    where would the vacuum line be located? In the skimmer?
    Largo, Florida
    Yeah, if you don't have a "cleaner port" you can just plug a hose into the skimmer and then the other end of the hose onto the vacuum head. If you don't mind getting in you could probably just use the hose, but the head lets you use a pole and stay dry while you vacuum.
    Jul 2011
    Quote Originally Posted by kelemvor View Post
    the only port I have in the pool is the one for the pressure cleaner. For the vacuum you obviously want suction, correct?
    where do you recommend picking one up like the vacuum you posted?
